Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Pry the screen by wedging the plastic opening tool under the screen at the charging port. Work your way around the screen with the plastic opening tool. When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
  • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
  • Work your way around the screen with the plastic opening tool.
  • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
  • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
Insérez ici votre traduction
