Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Remplacement des bandes adhésives fixant la batterie d'un iPhone 8, 8 Plus ou XR
Informations sur le tutoriel
= Terminé = Incomplet
Plus, XR XR, SE 2020
Plus, XR, or XR. SE 2020.
    Plus, iPhone XR, or iPhone XR. SE 2020. (For earlier iPhone models, [guide|56465|refer to this guide instead].) Any time you remove the battery, these strips must be replaced. The strips are easily damaged if not applied correctly, so you may want to have a spare set of strips on hand when following this guide for the first time. [ … ] These adhesive strips are different from those in prior-generation iPhones due to the presence of the wireless charging coil. The coil lies directly underneath the battery, which is secured with four adhesive strips that are contoured around the coil to avoid damaging it. [ … ] Before you begin, you should have removed the battery by following a guide like the ones linked below: [ … ] * [guide|101279|iPhone 8 Battery Replacement] * [guide|98260|iPhone 8 Plus Battery Replacement] * [guide|116553|iPhone XR Battery Replacement] * [guide|133814|iPhone SE 2020 Battery Replacement] If you need to replace the adhesive strips in a different model iPhone, use one of the following guides: [ … ] * [guide|107792|iPhone 5s, 5c, and SE Battery Adhesives Strips Replacement] * [guide|56465|iPhone 6, 6 Plus, 6s, 6s Plus, 7, and 7 Plus Battery Adhesive Strips Replacement] * [guide|117505|iPhone X, XS, and XS Max Battery Adhesive Strips Replacement]
      To reassemble your iPhone, return to the guide you used to remove the battery and follow the steps in reverse order. [ … ] [guide|101279|iPhone 8 Battery Replacement] [ … ] [guide|98260|iPhone 8 Plus Battery Replacement] [ … ] [guide|116553|iPhone XR Battery Replacement] [ … ] [https://www.ifixit.com/Guide/iPhone+SE+2020+Battery+Replacement/133814|iPhone SE 2020 Battery Replacement] [ … ] Remember to take your old battery to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      Décollez le large film en plastique bleu de votre nouveau set de bandes adhésives et jetez-le.
      Étape 2
      Une fois que les bandes adhèreront à la batterie, vous ne pourrez plus les retirer ou les repositionner. Si vous faites une erreur, vous devrez recommencer avec un nouveau set de bandes adhésives.
      Étape 3
      Utilisez vos doigts ou un morceau de tissu pour faire adhérer fermement les bandes à la batterie.
      Étape 4
      Retournez la batterie, détachez puis jetez les deux films en plastique bleu recouvrant les extrémités des bandes adhésives.
      Étape 5
      Saisissez le film en plastique rose en bas de la batterie et tirez doucement dessus.
      Étape 6
      Répétez l'étape précédente pour faire adhérer les extrémités des deux dernières bandes sur le bord supérieur de la batterie.
      Étape 7
      Retirez et jetez le petit film orange recouvrant les extrémités des bandes sur le bord supérieur de la batterie.
      Étape 8
      Posez la batterie dans votre iPhone y compris le large film en plastique rose.
      Étape 9
      Alignez le connecteur de la batterie et reconnectez-le.
      Étape 10
      En soulevant la batterie par le côté extérieur, faites-la basculer sur le côté pour accéder au dernier film.
      Étape 11
      Décollez alors le dernier grand film en plastique rose et jetez-le.
      Étape 12
      Orientez soigneusement la batterie et posez-la dans l'iPhone.
      Étape 13
      Appuyez sur le haut et le bas de la batterie pour la fixer fermement et faire adhérer les bandes adhésives à la coque arrière.
      Étape 14
      Veillez à déconnecter la batterie avant de remonter votre iPhone.
