Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the button by grabbing the tab over the button and pulling it out. it will not come out if the button is not depressed. Remove both metal sheets. when its at an angle, push it in a little and then pull it up so that it is pointing straight up. then, you can push it through.
  • Remove the button by grabbing the tab over the button and pulling it out.
  • it will not come out if the button is not depressed.
  • Remove both metal sheets. when its at an angle, push it in a little and then pull it up so that it is pointing straight up. then, you can push it through.
Insérez ici votre traduction
