Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Peel up the six cable loops securing the antenna cables to the upper case. Gently pull the cable loops slightly out of the channel cut into the upper case one at a time. Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
  • Peel up the six cable loops securing the antenna cables to the upper case.
  • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
  • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
  • Repeat this for all five retaining loops.
Insérez ici votre traduction
