Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 2
Étape 2
Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly. Remove the 3 #00 Phillips screws holding the joystick assembly in place. Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
  • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
Retirez délicatement la membrane du bouton Z ainsi que son circuit imprimé, en les faisant glisser vers la gauche et en les éloignant du bloc joystick.
Retirez les 3 vis cruciformes #00 qui maintiennent le bloc joystick dans la manette
