Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive. Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in. If the adhesive is hard to cut, use an iOpener to loosen it.
  • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
  • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
  • If the adhesive is hard to cut, use an iOpener to loosen it.
Insérez la pointe d'un médiator entre la coque arrière et le châssis central et faites-la glisser sur tout le tour du téléphone pour faire céder l'adhésif.
Si l'adhésif résiste trop, servez-vous d'un iOpener pour le faire ramollir.
[* black] Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
+ [* black] Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
[* icon_note] If the adhesive is hard to cut, [guide|11677|use an iOpener] to loosen it.
