Aller au contenu principal
Anglais
Français
Traduction de l’étape 11
Étape 11
Pull the hammer back. Now pull the thumb safety out of the frame. You'll need to wiggle it between safe and fire to release it from the hammer spur. The hammer must be pulled back to get this part out. The pin that holds the safety in position is under alot of pressure. it WILL fly out, so hold your hand next to it to stop it from flying out the window at the house next door. Plus this part is tiny, you lose it, you may not find it again.
  • Pull the hammer back. Now pull the thumb safety out of the frame.
  • You'll need to wiggle it between safe and fire to release it from the hammer spur. The hammer must be pulled back to get this part out.
  • The pin that holds the safety in position is under alot of pressure. it WILL fly out, so hold your hand next to it to stop it from flying out the window at the house next door. Plus this part is tiny, you lose it, you may not find it again.
  • See above
  • Once the thumb safety is removed, the grip safety will come out easily.
  • These 2 pins can be removed with finger pressure. The bigger one is for the trigger, and we'll take that out first.
Insérez ici votre traduction
