Aller au contenu principal
Comment transformer HP Pavilion Chromebook en ordinateur portable Linux
Anglais
Français
Traduction de l’étape 3
Étape 3
How to turn HP Pavilion  Chromebook into linux laptop, All chromebooks go to heaven!: étape 0, image 1 de 1
  • Press [ Ctrl ] [ Alt ] [ T ] to get to the crosh shell prompt on the chromebook.
  • Use the "shell" command to get to the shell prompt. Just type "shell" into the prompt and press enter.
  • Type the following (or cut and paste into a single command line). I include the full command in the next bullet point...
  • cd; curl -LO https://mrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh
  • You should get that menu (see graphic) with appropriate device data for HP Pavilion Chromebook etc. Press option 3 to flash a full UEFI capable rom onto your system. Note this is the end of your chromebook effectively once you pass the clearly identified "point of no return".
  • You can either perform the chromeos rom backup or not as the option presents itself (your choice). You will need that extra USB stick if you choose to backup the original rom. Do you feel lucky punk? Sorry :D
  • Once it is finished it will prompt you to power off and restart the device. At that point you can insert your new linux boot/install USB stick. From there you simply install like you would on any typical laptop.
  • I opted to go the full UEFI route on mine but it is optional. Follow the instructions under the FAQs (https://mrchromebox.tech/#faq) The fifth question there is answered with how to proceed to setup your UEFI boot option files correctly.
Appuyez sur [ Ctrl ] [ Alt ] [ T ] pour accéder à l'invite Crosh Shell sur le Chromebook.
Tapez ce qui suit (ou coupez et collez dans une seule ligne de commande). J'inclus la commande complète dans le point suivant...
CD; curl -LO https://mrchromebox.tech/firmware-util.s... && sudo bash firmware-util.sh
Vous devriez obtenir ce menu (voir graphique) avec les données de périphérique appropriées pour le Chromebook HP Pavilion, etc. Appuyez sur l'option 3 pour flasher une rom compatible UEFI complète sur votre système. Notez que c'est effectivement la fin de votre Chromebook une fois que vous avez passé le "point de non-retour" clairement identifié.
Vous pouvez soit effectuer la sauvegarde de la rom chromeos ou non selon l'option qui se présente (votre choix). Vous aurez besoin de cette clé USB supplémentaire si vous choisissez de sauvegarder la rom d'origine. Vous sentez-vous chanceux, punk? Désolé :D
Une fois terminé, il vous demandera d'éteindre et de redémarrer l'appareil. À ce stade, vous pouvez insérer votre nouvelle clé USB de démarrage/installation Linux. À partir de là, vous installez simplement comme vous le feriez sur n'importe quel ordinateur portable typique.
J'ai choisi d'emprunter la route UEFI complète sur le mien, mais c'est facultatif. Suivez les instructions de la FAQ (https://mrchromebox.tech/#faq). La cinquième question contient une réponse indiquant comment procéder pour configurer correctement vos fichiers d'options de démarrage UEFI.
