Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
In the following steps, you will use a heat gun to soften the adhesive securing the outer silver border around the underside of the front panel to the display.
  • In the following steps, you will use a heat gun to soften the adhesive securing the outer silver border around the underside of the front panel to the display.
  • With the heat gun set to low, start by heating the metal bezel surrounding the LCD.
  • When using the heat gun, the goal is to soften a layer of adhesive holding the bezel to the display assembly. Be very careful not to overheat the LCD, as it could cause permanent damage.
Insérez ici votre traduction
