Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
Caution: Lithium-ion batteries are fragile and can ignite if punctured or bent. Be careful when prying and do not use metal tools. Now finally, use the long flat tipped spudger and use it to carefully separate the battery's adhesive by going in at a low angle in several different directions, I found that going in towards one side, then the other, then down the middle worked well. don't stick it underneath and pry upwards, just separate the adhesive and it comes right out. Now finally, use the long flat tipped spudger and use it to carefully separate the battery's adhesive by going in at a low angle in several different directions, I found that going in towards one side, then the other, then down the middle worked well. don't stick it underneath and pry upwards, just separate the adhesive and it comes right out.
Carefully Remove the Battery
  • Caution: Lithium-ion batteries are fragile and can ignite if punctured or bent. Be careful when prying and do not use metal tools.
  • Now finally, use the long flat tipped spudger and use it to carefully separate the battery's adhesive by going in at a low angle in several different directions, I found that going in towards one side, then the other, then down the middle worked well. don't stick it underneath and pry upwards, just separate the adhesive and it comes right out.
Insérez ici votre traduction
