Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 1
Étape 1
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device. Pry open the aluminum plate using the Plastic Opening Tool(s). Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
  • Pry open the aluminum plate using the Plastic Opening Tool(s).
  • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
Insérez ici votre traduction
