Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
First component on the menu: the dual microphone assembly near the bottom of the face plate. It takes some heat and careful spudgering to remove these cleanly. Fortunately, there's no need for this unless you're replacing broken mics, so the risk of collateral damage is low. Where the original Vive got by with a single mic, the Pro's twin mics offer improved noise cancellation during online play.
  • First component on the menu: the dual microphone assembly near the bottom of the face plate.
  • It takes some heat and careful spudgering to remove these cleanly. Fortunately, there's no need for this unless you're replacing broken mics, so the risk of collateral damage is low.
  • Where the original Vive got by with a single mic, the Pro's twin mics offer improved noise cancellation during online play.
  • Next we snag the faceplate-mounted mainboard, which wrangles signals from the IR sensor arrays, cameras, and microphones.
  • Beneath the board, we find a hefty slab of copper foil, likely used for EMI shielding as well as keeping things cool. (Passive cooling would be the way to go, to keep this device lightweight and quiet enough to wear on your face!)
  • And under that we find the cameras! Two separate units with no identifiable markings. HTC says the additional camera makes for an improved Chaperone feature, as well as some basic hand tracking.
Insérez ici votre traduction
