Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
It's very easy for the rubber display gasket to deform when exposed to heat, so it is best to remove it before using a heat gun to remove the display glass. Insert the tip of a spudger underneath the black rubber gasket at the bottom right corner of the display assembly.
  • It's very easy for the rubber display gasket to deform when exposed to heat, so it is best to remove it before using a heat gun to remove the display glass.
  • Insert the tip of a spudger underneath the black rubber gasket at the bottom right corner of the display assembly.
  • Gently pry the wide edge of the gasket up from the back case.
Insérez ici votre traduction
