Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 11 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board. To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery. Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
  • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
  • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
  • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
  • Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
Retirez la vis cruciforme #000 de 2,3 mm qui fixe le connecteur de la batterie à la carte mère.
Pour réduire les risques de court-circuit, vous pouvez utiliser un pic d'isolation de la batterie pour déconnecter la batterie.
Glissez un pic d'isolation de la batterie sous la zone du connecteur de la batterie de la carte mère et laissez-le en place pendant que vous continuez votre réparation.
[* red] Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
[* icon_note] To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
[* icon_caution] Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
[* black] Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
