Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the following screws securing the speaker enclosure to the rear case:
  • Remove the following screws securing the speaker enclosure to the rear case:
  • One 2.5 mm Phillips screw
  • One 1.5 mm Phillips screw
  • One 2.7 mm standoff screw
  • Standoff screws are best removed using an [produit lié absent ou désactivé : IF145-343-1] and driver handle.
  • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
Insérez ici votre traduction
[* black] Remove the following screws securing the speaker enclosure to the rear case:
[* red] One 2.5 mm Phillips screw
[* orange] One 1.5 mm Phillips screw
[* yellow] One 2.5 mm Phillips screw
[* green] One 2.7 mm standoff screw
[* icon_note] Standoff screws are best removed using an [product|IF145-343|new_window=true] and [product|IF145-326|driver handle|new_window=true].
[* icon_caution] In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
