Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the point of a spudger to pry up and disconnect the antenna cable from the logic board. Use the point of a spudger to pry up and disconnect the antenna cable from the logic board.
  • Use the point of a spudger to pry up and disconnect the antenna cable from the logic board.
Décollez délicatement le haut-parleur de la nappe du connecteur de charge Lightning.
Retirez l'enceinte du haut-parleur.
[* black] Gently peelUse the speaker assembly offpoint of a spudger to pry up and disconnect the Lightning connector ribbon cable.
[* black] Remove the speaker enclosure
antenna cable from the assemblylogic board.
