Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 6
Étape 6
Angle the Lightning connector assembly and pull it out of its recess. Remove the four metal washers and set them aside for reassembly. Before reassembly, use the opening tool or the flat end of a spudger to remove all adhesive residue from the rear case. You can use high-concentration isopropyl alcohol to help with the stubborn spots.
  • Angle the Lightning connector assembly and pull it out of its recess.
  • Remove the four metal washers and set them aside for reassembly.
  • Before reassembly, use the opening tool or the flat end of a spudger to remove all adhesive residue from the rear case. You can use high-concentration isopropyl alcohol to help with the stubborn spots.
Insérez ici votre traduction
[* black] Angle the Lightning connector assembly and pull it out of its recess.
[* red] Remove the four metal washers and set them aside for reassembly.
[* icon_reminder] Before reassembly, use the opening tool or the flat end of a spudger to remove all adhesive residue from the rear case. You can use high-concentration isopropyl alcohol to help with the stubborn spots.
