Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 2
Étape 2
Use the opening tool to pry up and disconnect the Lightning connector cable connector from its socket on the logic board. Use the opening tool to pry up and disconnect the Lightning connector cable connector from its socket on the logic board.
  • Use the opening tool to pry up and disconnect the Lightning connector cable connector from its socket on the logic board.
Décollez soigneusement le câble au bord de la prise jack.
Faites attention à ne pas perdre le joint en plastique entre le connecteur pour casque et la coque externe. En alignant le connecteur pour casque, veillez à bien aligner ce joint correctement.
[* black] Carefully peel off and remove the grounding cable from the edge ofUse the headphone jack.
[* black] Take care not
opening tool to losepry up and disconnect the plastic gasket between the headphoneLightning connector andcable connector from its socket on the outer shell. While aligning the headphone connector, make sure to align this gasket correctlylogic board.
