Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the following screws securing the Lightning connector assembly to the rear case:
  • Remove the following screws securing the Lightning connector assembly to the rear case:
  • One 2.9 mm Phillips screw
  • During re-installation, make sure that the headphone jack's plastic protrusion lies above the metal washer.
  • One 1.5 mm Phillips screw
  • Two 3.3 mm Phillips screws
Soulevez le haut-parleur de la nappe de câble du connecteur Lightning.
Si vous remplacez le connecteur Lightning avec une nouvelle pièce, prenez soin de transférer la coque en caoutchouc autour du microphone. Vous pouvez le faire en utilisant un spudger.
[* black] Gently peelRemove the speaker assembly away fromfollowing screws securing the Lightning connector ribbon cable.
[* icon_note] If you are replacing
assembly to the Lightning connector with a new partrear case:
[* red] One 2.9 mm Phillips screw
[* icon_reminder] During re-installation
, make sure to transferthat the rubber casing aroundheadphone jack's plastic protrusion lies above the microphone. You can do this using a spudger.metal washer.
[* orange] One 1.5 mm Phillips screw
[* yellow] Two 3.3 mm Phillips screws
