Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 11 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets. To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board. During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
  • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
  • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
Utilisez le bout plat ce votre spatule ou bien votre ongle pour détacher avec précaution les connecteurs des deux nappes de la vitre tactile de leurs prises.
Pour éviter toute détérioration de l'iPad, faites levier seulement sur les connecteurs et non sur leurs prises sur la carte mère.
[* black] Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
[* icon_caution] To avoid damaging your iPad, pry only on the connectors themselves, '''not''' on the socket on the logic board.
[* icon_reminder] During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
