Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Remplacement du panneau frontal de l'iPad 6 Wi-Fi
Informations sur le tutoriel
= Terminé = Incomplet
    Use this guide to replace the front glass and digitizer assembly on an iPad 6. [ … ] '''Note that since the Touch ID sensor in the home button is paired to the logic board, this guide includes instructions for removing the home button. In order to retain Touch ID functionality, you need to transfer the original home button to the new front panel assembly.''' [ … ] '''Warning: the battery isolation method in this guide is outdated, and may result in irreversible damage to the battery pins of the logic board, effectively destroying it. If'''Be very careful when you choose to isolate the battery this way, heed all warnings and work extremely carefully. using a battery blocker.''' The battery contacts are easily damaged, resulting in irreversible damage. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.''' components.
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
