Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 2
Étape 2
Plug the charger into a surge-protected A/C outlet.
  • Plug the charger into a surge-protected A/C outlet.
  • Wait until you hear the power connect chime (you should also see the battery charge symbol onscreen).
  • You'll typically hear the chime in 10 seconds or less—unless your battery charge level is very low, in which case it may take up to 15 minutes.
  • Power on your MacBook by pressing the power button.
  • Once the MacBook successfully powers on, you can disconnect the 5 W charger, and use/charge your MacBook normally.
  • If the MacBook fails to power on after 15 minutes, there may be an issue with your repair.
Insérez ici votre traduction
