Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 4
Étape 4
With the exposed adhesive facing down, carefully align the strips into your iPhone's rear case. Position the black tab very close to, but not quite touching, the black plastic speaker housing on the bottom right. Set the adhesive strips into the rear case and allow them to stick.
  • With the exposed adhesive facing down, carefully align the strips into your iPhone's rear case.
  • Position the black tab very close to, but not quite touching, the black plastic speaker housing on the bottom right.
  • Set the adhesive strips into the rear case and allow them to stick.
L'adhésif à découvert toujours orienté vers le bas, alignez soigneusement les languettes dans la coque arrière de votre iPhone.
Positionnez la languette noire juste à côté du boîtier en plastique noire du haut-parleur dans le coin inférieur droit, mais sans le toucher.
Posez les bandes adhésives sur la coque arrière et faites-les adhérer.
[* black] With the exposed adhesive facing ''down'', carefully align the strips into your iPhone's rear case.
[* icon_note] Position the black tab very close to, but not quite touching, the the black plastic speaker housing on the bottom right.
[* black] Set the adhesive strips into the rear case and allow them to stick.
