Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a  screwdriver. Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver. These screws can also be Torx on some models.
  • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
  • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
  • These screws can also be Torx on some models.
  • Pull off the rear case.
Insérez ici votre traduction
