Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 153 tutoriels qui comprennent cette étape.
Traduction de l’étape 14
Étape 14
Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
[* black] Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth. |
[* black] Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass. |
[* black] The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged. |
