Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the fuse that correspondences to the electrical failure in the vehicle by carefully pulling the fuse straight up and out of the fuse box. It is safe to do this with your hands, just move slowly and carefully as you remove the blown fuse.
  • Remove the fuse that correspondences to the electrical failure in the vehicle by carefully pulling the fuse straight up and out of the fuse box.
  • It is safe to do this with your hands, just move slowly and carefully as you remove the blown fuse.
  • Check for damage or discoloration in the fuse.
  • Replace the damaged fuse with the new fuse by pushing it back into the appropriate fuse port. The new fuse should sit flush with the other fuses and may click when inserted correctly.
  • Close the fuse box and fasten latch on left side of fuse box.
Insérez ici votre traduction
