Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward  the back of the computer. There are two length of screws. Eight screws are  3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge. There are two length of screws. Eight screws are  3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
  • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
  • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
Insérez ici votre traduction
