Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Remplacement de l'écran du Samsung Galaxy Tab S3
Informations sur le tutoriel
= Terminé = Incomplet
    If you haveUse this guide to replace a crackcracked or [[Samsung Galaxy Tab S3 Troubleshooting#Section_An_Image_on_the_Screen_Won_t_Go_Away|excessive burn-in damage]]malfunctioning display on your Samsung Galaxy Tab S3's screen, you will needS3 tablet (identified with model number SM-T820). [ … ] The display assembly is the output component to replacepresent information and is made up of the entireglass panel, digitizer, and AMOLED display sandwiched together. Your display assembly. You may also need to replacebe [https://www.ifixit.com/Wiki/Samsung_Galaxy_Tab_S3_Troubleshooting|replaced] if the rear glass panel if itcracks or is cracked. This guidebroken because this will showaffect its touch screen capabilities. It could also experience something called “[https://www.cnet.com/news/oled-screen-burn-in-what-you-need-to-know/|screen burn-in]” that happens on AMOLED displays. “Screen burn-in” is when some of the individual light-emitting pixels powering the display will dim the more they are used, causing uneven lighting and colors. [ … ] In step 1 of this guide, you howwill need to remove anduse the iOpener, which is a microwavable heating tool used to loosen adhesive attached to the display. Carefully follow the [https://www.ifixit.com/Guide/iOpener+Instructions/11677|iOpener heating instructions] to avoid burning yourself. If your display is shattered, follow [https://www.ifixit.com/Guide/Taping+Over+The+Display/103487|this guide] to reinforce your screen to avoid injury until you replace both components properly.the display. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning this guide.
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      Pour ramollir l'adhésif qui maintient la tablette ensemble, chauffez les bords du panneau de verre à l'aide d'un iOpener chauffé sur le bord de l'appareil.
      Étape 2
      Placez une ventouse près du bord que vous avez chauffé avec le iOpener.
      Étape 3
      En continuant le long du bord à l'aide de l'outil d'ouverture, utilisez une carte en plastique pour séparer le verre du cadre central.
      Étape 4
      Lorsque vous retirez le panneau de verre, veillez à ne pas déchirer le ruban reliant la carte mère à l'écran.
      Étape 5
      Répétez les étapes 3 à 7 pour retirer le panneau de verre arrière sur le côté opposé de l'appareil.
