Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
Identify the two mounting bolts on the rear of the caliper. Using a 12 mm wrench or socket, remove the two caliper mounting bolts. Alternatively, you may remove only the bottom mounting bolt and, using the top bolt as a hinge, rotate the caliper up and away from the rotor to access the brake pads. If you do this, skip the next step.
  • Identify the two mounting bolts on the rear of the caliper.
  • Using a 12 mm wrench or socket, remove the two caliper mounting bolts.
  • Alternatively, you may remove only the bottom mounting bolt and, using the top bolt as a hinge, rotate the caliper up and away from the rotor to access the brake pads. If you do this, skip the next step.
Insérez ici votre traduction
