Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
Lifting the battery
  • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
  • If you are having trouble peeling the battery up or if the tab breaks, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
  • Wait about one minute for the alcohol solution to weaken the adhesive. Use an opening tool to gently lift the battery by its edge.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
  • If you still have trouble peeling the battery up, use an iOpener or hair dryer to heat the rear case of the iPhone and soften the adhesive.
  • Overheating the iPhone may ignite the battery.
Utilisez la languette en plastique transparente pour retirer la batterie de l'adhésif qui la maintient à l'iPhone.
Si vous rencontrez des difficultés à décoller la batterie, utilisez un iOpener ou un séchoir pour chauffer le boîtier de l'iPhone et ramollir l'adhésif.
La languette plastique est fragile et peut casser. Si la languette rompt avant le retrait de la batterie, consultez les étapes suivantes.
[title] Lifting the battery
[* black] Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
[*[* icon_note] If you are having trouble peeling the battery up or if the tab breaks, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
black] Wait about one minute for the alcohol solution to weaken the adhesive. Use an opening tool to gently lift the battery by its edge.
[* icon_caution] Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
[* icon_reminder] If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
[* icon_note]
[* black] The plastic tab is fragile and may break. If your tab breaks beforeicon_caution] Overheating the battery is freed, refer toiPhone may ignite the following stepsbattery.
[* icon_note]
