Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case. Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case. Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case.
  • Starting under the cable connection, use the flat of a spudger to pry the Wi-Fi antenna up from the rear case.
En commençant par en dessous du câble de connexion, utilisez le bout plat d'un spudger pour soulever l'antenne WiFi du boîtier.
