Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the following screws from the metal power switch bracket between the rear facing flash and camera windows: Single 2.9 mm standoff screw
  • Remove the following screws from the metal power switch bracket between the rear facing flash and camera windows:
  • Single 2.9 mm standoff screw
  • Standoff screws are best removed using an [produit lié absent ou désactivé : IF145-343-1] and driver handle.
  • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  • Single 1.6 mm Phillips screw
  • Remove the metal power switch bracket.
Retirez les vis suivantes du support en métal du bouton marche/arrêt entre le flash arrière et les fenêtres de la caméra :
une vis standoff 2,9 mm
Même si ces vis ont la forme d'une vis cruciforme, le meilleur outil pour les enlever serait un tournevis plat de 2,5 mm.
une vis cruciforme 1,6 mm
Enlevez le support métallique du bouton marche/arrêt.
[* black] Remove the following screws from the metal power switch bracket between the rear facing flash and camera windows:
[* red] Single 2.9 mm standoff screw
[* black] While theseicon_note] Standoff screws have a Phillips bit pattern, we found theare best removal tool to beremoved using an [product|IF145-343|new_window=true] and [product|IF145-326|driver handle|new_window=true].
[* icon_caution] In
a 2.5 mmpinch, a small flathead driverscrewdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
[* icon_caution] In
[* orange] Single 1.6 mm Phillips screw
[* black] Remove the metal power switch bracket.
