Anglais
Français
Remplacement du panneau frontal de l'iPhone 5
Conditions préalables au tutoriel
Tous les tutoriels préalables doivent être traduits avant que cette traduction ne soit considérée comme complète.
Remplacement de l'écran complet de l'iPhone 5
Remplacement du haut-parleur interne iPhone 5
Remplacement de la caméra avant et du capteur de proximité de l'iPhone 5
Remplacement de la nappe du bouton home de l'iPhone 5
Informations sur le tutoriel
= Terminé = Incomplet
Front PanelLCD and Digitizer
5 Front Panel LCD and Digitizer Replacement
the Front Panel LCD and digitizer on your iPhone 5.
    Use this guide to replace a cracked or broken screen inFor an iPhone 5. This guide includes removing the front-facing camera, LCD shield plate, earpiece speaker, easier repair, use our [product|IF118-028|fix kit|new_window=true] and home button assembly—all of which should be transferred to your new display. If your replacement part contains all those components, follow this [https://www.ifixit.com/Guide/iPhone+5+Display+Assembly+Replacement/10588|much shorter guide]. [guide|10588|shorter guide] to replace your iPhone 5’s entire screen. [ … ] You can also useFor more advanced fixers, this guide to will help you replace ''only'' the [https://www.ifixit.com/Guide/iPhone+5+Front+Panel+Replacement/10906#s38524|front panel iPhone’s LCD + digitizer assembly cable bracket]. (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the front-facing camera, earpiece speaker, LCD shield plate, and home button assembly. [ … ] NeedYou can also use this guide to replace the [guide|10906|front panel assembly cable bracket|stepid=38524]. [ ] Need a guide for the [guide|22096|iPhone 5s screen] LCD and digitizer] instead? We got you covered! [ … ] [video|http://youtu.be/-lfP-3z_9Zg]
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce résumé en 1-2 phrases brèves apparaîtra dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      Utilisez un outil d'ouverture en plastique pour décoller la nappe du bouton Home.
      Étape 2
      Utilisez un outil d'ouverture en plastique pour décoller le bouton Home.
      Étape 3
      Retirez les deux vis cruciformes 1,2 mm de chaque côté de l'écran LCD (quatre au total).
      Étape 4
      Retirez les deux vis de la plaque de protection de l'écran LCD :
      Étape 5
      Retirez la plaque de protection de l'écran LCD de l'écran.
      Étape 6
      Il vous reste l'écran vide.
