Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Push a plastic card between the right-most battery cell and the upper case, cutting the adhesive between the two. Throughout this procedure, be careful not to damage any of the battery cells with your tools. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
  • Push a plastic card between the right-most battery cell and the upper case, cutting the adhesive between the two.
  • Throughout this procedure, be careful not to damage any of the battery cells with your tools. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
  • When using the hot iOpener method, if you encounter significant resistance to prying, stop and use the iOpener to reheat the section you're working on.
Insérez ici votre traduction
