Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board. To reduce the risk of a short, you can use a battery isolation pick to isolate the battery. The battery isolation pick or battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board. If you use this method, take extreme care to insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side.
  • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
  • To reduce the risk of a short, you can use a battery isolation pick to isolate the battery.
  • The battery isolation pick or battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board. If you use this method, take extreme care to insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side.
  • Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
Retirez la seule vis cruciforme de 2,3 mm fixant le connecteur de la batterie sur la carte mère.
Pour réduire le risque d'un court-circuit, vous pouvez utiliser un médiator d'isolation de la batterie pour déconnecter la batterie.
Faites glisser un médiator d'isolation de la batterie en dessous de la zone de connecteur de la batterie sur la carte mère et laissez-le en place pendant votre travail.
[* red] Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
-[* icon_note] To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
+[* icon_note] To reduce the risk of a short, you can use a battery isolation pick to isolate the battery.
+[* icon_caution] The battery isolation pick or battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board. If you use this method, take extreme care to insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side.
[* black] Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
