Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Disconnect the battery by inserting a Battery Blocker underneath the logic board to isolate it from the battery's contacts. Insert the Battery Blocker at a slight angle first with one side under the logic board, then slide the rest in over the battery contacts. This may require carefully applied force as the logic board has adhesive holding it onto the case.
  • Disconnect the battery by inserting a Battery Blocker underneath the logic board to isolate it from the battery's contacts.
  • Insert the Battery Blocker at a slight angle first with one side under the logic board, then slide the rest in over the battery contacts.
  • This may require carefully applied force as the logic board has adhesive holding it onto the case.
  • Unless specified otherwise, leave the Battery Blocker in place until you have completed your repairs.
Insérez ici votre traduction
