Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 33 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board. On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal. Carefully lift the I/O board and remove it from the lower case.
  • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
  • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
  • Carefully lift the I/O board and remove it from the lower case.
Retirez les deux vis Torx T5 de 3,1 mm fixant la carte E / S sur la carte logique.
Soulevez soigneusement la carte d'E / S et retirez-la ddv boitier inférieur.
[* red] Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
[* orange] On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
[* black] Carefully lift the I/O board and remove it from the lower case.
