Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Apply a suction cup as close as possible to the bottom edge of the phone. If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed. Lift on the suction cup and insert an opening pick under the rear glass.
  • Apply a suction cup as close as possible to the bottom edge of the phone.
  • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  • Lift on the suction cup and insert an opening pick under the rear glass.
  • The rear glass very fragile and can break if you use too much force or attempt to pry with metal tools.
Insérez ici votre traduction
