Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. Pull the RAM chip directly out from its connector. If there are two RAM chips installed, repeat the above procedure for the second chip.
  • Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the RAM chip directly out from its connector.
  • If there are two RAM chips installed, repeat the above procedure for the second chip.
Insérez ici votre traduction
