Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
Once the screen is warm to the touch, apply a suction cup  to the lower edge of the phone. If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed. Lift on the suction cup, and insert a halberd spudger or an opening pick under the display assembly.
  • Once the screen is warm to the touch, apply a suction cup to the lower edge of the phone.
  • If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  • Lift on the suction cup, and insert a halberd spudger or an opening pick under the display assembly.
  • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
  • Start to slide the halberd spudger/opening pick along the lower edge of the phone to cut the adhesive. Leave an opening pick at the corner to prevent the adhesive from resealing.
  • The screen's flex cable is located just below the midpoint on the side of the power button, and may interfere with your cutting tool.
  • Continue to slide the halberd spudger/opening pick along the side of the phone and insert another opening pick.
Une fois que l'écran est chaud au toucher, appliquez une ventouse sur le bord inférieur du téléphone.
Si l'écran du téléphone est fissuré, la ventouse risque de ne pas adhérer. Essayez de soulever avec de l'adhésif fort ou collez la ventouse avec de la superglue et laissez sécher avant de continuer.
Soulevez la ventouse et insérez un spudger hallebarde ou un médiator en dessous de l'écran.
À cause du verre incurvé, poussez le médiator vers le haut plutôt que de l'insérer parallèlement au plan du téléphone.
Commencez à faire glisser le spudger hallebarde/médiator le long du bord inférieur du téléphone pour couper l'adhésif. Laissez un médiator dans le coin pour empêcher l'adhésif de recoller.
La nappe de l'écran est située juste en dessous du point médian sur le côté du bouton de marche et peut interférer avec votre outil de coupe.
Continuez à faire glisser le spudger hallebarde/médiator sur le côté du téléphone et insérez un autre médiator.
