Aller au contenu principal
Anglais
Français
Traduction de l’étape 12
Étape 12
Insert an opening pick between the power and volume button circuit board and the frame. Slide the pick behind the circuit board, across the whole board, to separate it from the adhesive securing it to the frame. If it's difficult to slide the pick behind the circuit board, try heating the circuit board to soften its adhesive.
  • Insert an opening pick between the power and volume button circuit board and the frame.
  • Slide the pick behind the circuit board, across the whole board, to separate it from the adhesive securing it to the frame.
  • If it's difficult to slide the pick behind the circuit board, try heating the circuit board to soften its adhesive.
Insérez un médiator entre le circuit imprimé des boutons de marche et de volume et le châssis.
Faites glisser le médiator sous tout le long du circuit imprimé, pour le séparer de l'adhésif qui le fixe au châssis.
Si vous avez du mal à faire glisser le médiator derrière le circuit, essayez de le faire chauffer pour ramollir l'adhésif.
