Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass. Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass. Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
  • Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
  • Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
Faites glisser le médiator tout le long du bord supérieur du téléphone pour couper l'adhésif qui fixe la coque arrière.
Ralentissez et faites plus attention quand vous arrivez aux coins. La partie incurvée des bords gauche et droit de la vitre est très fragile et risque de se fissurer si le médiator la heurte.
