Aller au contenu principal
Remplacement de la carte mère du HTC myTouch 3G
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
HTC myTouch 3G Motherboard Replacement, Separate the Circuit Board: étape 0, image 1 de 3 HTC myTouch 3G Motherboard Replacement, Separate the Circuit Board: étape 0, image 2 de 3 HTC myTouch 3G Motherboard Replacement, Separate the Circuit Board: étape 0, image 3 de 3
  • Place a finger between the circuit board and front cover, and lift the circuit board gently.
  • Separate the circuit board from the front cover and screen to access the ribbon cable holding them together. Detach the ribbon cable.
  • Finish separating the circuit board from the front panel.
Placez un doigt entre la carte de circuit imprimé et le capot avant et soulevez doucement.
Séparez le circuit imprimé du capot avant et de l'écran pour détacher le câble plat qui les maintient ensemble.
Finissez de séparer le circuit imprimé du panneau avant.
[title] Separate the Circuit Board
-[* black] Place a finger between the circuit board and front cover, and lift up gently.
-[* red] Separate the circuit board from the front cover and screen to detach the ribbon cable holding them together.
+[* black] Place a finger between the circuit board and front cover, and lift the circuit board gently.
+[* red] Separate the circuit board from the front cover and screen to access the ribbon cable holding them together. Detach the ribbon cable.
[* black] Finish separating the circuit board from the front panel.
