Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 9
Étape 9
After you have thoroughly dried your bearing, you can now relubricate the bearing.  To do this, simply coat all inside parts with the lubricant and spin the bearing in order to disperse the lubricant fully. Make sure to spin the bearing immediately after the lubrication process.
  • After you have thoroughly dried your bearing, you can now relubricate the bearing. To do this, simply coat all inside parts with the lubricant and spin the bearing in order to disperse the lubricant fully.
  • Make sure to spin the bearing immediately after the lubrication process.
  • Warning! The bearing lubricant is harmful if swallowed and can cause skin irritation. Be sure to keep away from open flames because the lubricant is flammable.
Insérez ici votre traduction
