Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Use a spudger to gently lift the battery power connector, disconnecting the battery. Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Disconnect the battery
  • Use a spudger to gently lift the battery power connector, disconnecting the battery.
  • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Déconnectez la batterie en soulevant délicatement le connecteur d'alimentation de la batterie avec une spatule.
Soulevez le connecteur de façon à ce qu'il ne risque pas de toucher sa prise. Un contact accidentel pendant la réparation pourrait endommager votre MacBook Pro.
[title] Disconnect the battery
[* black] Use a spudger to gently lift the battery power connector, disconnecting the battery.
[* black] Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
