Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Your distributor should now look the same as the one pictured to the left. Take note of the notch on the body of the distributor opposite the vacuum advance can: this is where the new leads exit.
  • Your distributor should now look the same as the one pictured to the left.
  • Take note of the notch on the body of the distributor opposite the vacuum advance can: this is where the new leads exit.
  • Place the new breaker plate back on the distributor, so that the threads face up, and the advance pin slides into the vacuum advance shaft.
  • Place the ignition module on the threaded studs as shown.
  • Set one end of the ground strap on the stud nearest to the notch and loosely put on the two locking nuts.
Insérez ici votre traduction
