Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
Point the timing light at the timing scale The light will strobe when the cylinder fires and a mark on the crank shaft pulley will become visible.
  • Point the timing light at the timing scale
  • The light will strobe when the cylinder fires and a mark on the crank shaft pulley will become visible.
  • The mark will appear next to the timing scale. The mark next to the timing scale indicates where the timing is currently set.
  • There are numbers on the scale, although they may be faded, and your timing value will likely be in between the marked values
  • The scale contains major marks at 0, 8, and 16 with minor marks at 4 and 12 Before Top Dead Center (BTDC)
  • All models will have differing timing values depending on the year and transmission.
  • Our model-year was 1965 which has an ideal timing value of 14 degrees BTDC (in between 12 and 16 marks)
  • For other model-years, consult the list of timing values provided here
Insérez ici votre traduction
