Aller au contenu principal
Anglais
Français
Traduction de l’étape 12
Étape 12
Use a flat blade screwdriver to 'walk' each of the two brass brush housings away from the motor shaft. After the brass brush housings are separated from their housing, the brush spade connectors simply slide out. After the brass brush housings are separated from their housing, the brush spade connectors simply slide out.
  • Use a flat blade screwdriver to 'walk' each of the two brass brush housings away from the motor shaft.
  • After the brass brush housings are separated from their housing, the brush spade connectors simply slide out.
Insérez ici votre traduction
