Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Now you must attach the 1/3 Valve Cover, which is essentially 1/3 of a valve cover that keeps the oil in while exposing the valves so you can adjust them when the engine is running. Place the valve cover on the lower side of the valves and line up the bolt holes. Verify the gasket is in place and use the bolts you previously removed to attach the adjustment cover.
  • Now you must attach the 1/3 Valve Cover, which is essentially 1/3 of a valve cover that keeps the oil in while exposing the valves so you can adjust them when the engine is running.
  • Place the valve cover on the lower side of the valves and line up the bolt holes. Verify the gasket is in place and use the bolts you previously removed to attach the adjustment cover.
Insérez ici votre traduction
