Aller au contenu principal
Anglais
Français
Remplacement du rail du Joy-Con droit de la Nintendo Switch
Informations sur le tutoriel
= Terminé = Incomplet
Right Joy- Con Sensor Rail
Nintendo Switch Right Joy- Con Sensor Rail Replacement
A free guide on how to replace theReplace a broken or faulty right Joy- Con sensor rail on athe Nintendo Switch gaminggame console.
    Follow this guide to replace thea broken or faulty right Joy- Con sensor rail in aon the Nintendo Switch gaminggame console.
    '''Warning''': the Joy-Con rail screws are torqued down and can easily strip. Make sure that you’re using a JIS #0 screwdriver to remove them.
    '''Note:''' When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Since normal thermal paste isn’t designed to bridge large gaps, the closest replacement is K5 Pro viscous thermal paste.
    '''Note:''' This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
      Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Device/Nintendo%20Switch|Nintendo Switch Answers community] for help.
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      Étape 2
      Étape 3
      Étape 4
